We applied an ACL rule to a port. ACL Rules are created at config time and applied to a port when the port is removed from the Aggregator when TCP tracking condition fails. This allows the switch to divert packets to the CPU even though the port is not an active LAG member. Normally, ports removed from the LAG drop all ingress packets.
No action required - Informational message only.
Info
ACL %ruleName% applied to port %port%
| Name | Type |
| port | SlotPort |
| ruleName | String |
